N2O is here!!
Old Dec 29, 2007 | 12:38 PM
hedsNcam88's Avatar
Default N2O is here!!
My christmas present came in today, a new NX wet kit!!
After reading around on here for quite a while i made a list of some stuff i might need come spring time. I plan on jetting it at 100hp, and then getting a good tune.
-Bottle pressure gauge
-NGK TR-6's
-Fuel pressure safety switch
-Window switch
-Bottle heater
-Activation switches
I know alot of guys on here are real smart when it comes to nitrous, and if i forgot anything please post. Thanks
Old Dec 29, 2007 | 03:29 PM
snake charmer's Avatar
larger injectors
Old Dec 29, 2007 | 03:34 PM
Alt's Avatar
Alt
What do you need larger injectors for, its a wet shot. Looks like you've got everything I can think of. Maybe a wideband so you can check your AFR or some solenoid mounts. I am a fan of a purge on a wet shot as well.
Old Dec 30, 2007 | 12:51 AM
hedsNcam88's Avatar
thanks, i might get a purge valve put it later down the road if i have the money. how much do widebands go for?
Old Dec 30, 2007 | 09:17 AM
99FRC's Avatar
Make sure you get a window switch with a built in WOT switch like the one from Nitrous Outlet. Looks like you've got everything else. You shouldn't need bigger injectors with the wet kit.
Good luck!
99 FRC
Old Dec 30, 2007 | 10:09 AM
Alt's Avatar
Alt
There is a PLX Wideband GP going on right now for $225 shipped. Thats quite a price reduction compared to MSRP and to other widebands and is the one that I purchased. Innovate also carries 2 different widebands, one is mobile and one is not. There are a few different avenues for you to try out.
