Relay Problem?
Old Jan 4, 2008 | 10:28 PM
BlackhawkSS's Avatar
Default Relay Problem?
Ok i jst rewired my 5177 kit that i havent used in years. I have no FPSS, nos opener, nx heater, purge using a WOT switch.
I tested the noids to the battery and everything "clicks"
Issue #1--With the system armed I press the WOT switch and get the relay to click but NOT the noids. I dont have a bottle hooked up, just hooked up to the opener/heater.
Issue #2--How can I test/warm the NX heater without the bottle being hooked up (havent filled it yet)?
Hopefully easy solutions. Thanks
Old Jan 4, 2008 | 11:15 PM
HAHA, im retarded, um so ya it was the inline fuse for issue #1....wasnt there, amazing what you forget u misplace/remove over the years.
Still havent figured out the bottle heater issue.
Old Jan 4, 2008 | 11:33 PM
Looks like a may have found an issue.
The switch is not a 3 prong switch like NX instructions has. I installed a 2 prong and looks like one is wired to 12 volt switch and other is ran back to the transducer.
So looks like im missing a ground. Odd, but do i need a ground to the switch?
