Does anyone make a progressive controller that pulls timing?
Old Jan 6, 2008 | 03:24 PM
Cliff's Avatar
Default Does anyone make a progressive controller that pulls timing?
I was wondering if any one makes a progressive controller for a "direct port" that I can pull a set amount of timing and change the amount of timing as desired. So I can run on motor full timing and then decrease timing for any shot of nitrous I choose. Thanks.
Old Jan 7, 2008 | 09:54 AM
Chris@NitroDaves
Guest
Posts: n/a
At this time there is no progressive controller that will control timing also. You can get a timing controller and then get a porgresive and use the two in conjuction. Thats what i'm doing on my car ( I have the P gauge and then i paired it with the timing tuner ).
-Chris
Old Jan 7, 2008 | 01:03 PM
BadAssFast's Avatar
You can pull timing with a tune (that uses valet mode) and switch and use a progressive controller.
