Standalone Fuel Cell
Old Jan 7, 2008 | 04:00 PM
ls1camaro's Avatar
Default Standalone Fuel Cell
Have A Nx Mass Air Flo System I'am Going To Run A Standalone Fuel Cell On Low Pressure I BEEN TOLD TO CHANGE JETS .Where Can I Get The Jets THANKS JOHNNY
Old Jan 7, 2008 | 04:30 PM
TARZAN's Avatar
This has always worked for me
http://www.robietherobot.com/NitrousJetCalculator.htm
Or you could call up whomever you purchased the fuel cell from, and get their advice, I'd guess the low pressure setting is 7 psi, but I can't be sure, since you didn't say
-Will
Old Jan 9, 2008 | 07:09 PM
ls1camaro's Avatar
Guess What I'am Asking Is If I Run The Stand Along On Low Pressure Do I Need To Change The Fuel Jet ?i Heard If Ran On Low Pressure Had To Change The Fuel Jet.
Old Jan 9, 2008 | 07:33 PM
b00sted's Avatar
If your kit was originally intended for EFI, and you run a low-pressure system, you need to compensate and add fuel. You're going from 58-60 psi down to 6-7, there's a big differnce in flow. Call NX and tell them what you're doing, they can recommend what pill to run and what to set the system at. I run my standalone system at 6.5-7psi, but it's a carb system, so I can run the factory jets and the tune is dead on.
Once you have the right jet you can make a pass and adjust the standalone's regulator to fine tune.(Or just add or take out fuel via the EFI system if you have the capabilities and know-how).
BTW: That calculator above will give you a slightly high jet size. Not a bad thing at all, but you'll probably end up going down a few sizes to get the tune right.
Old Jan 9, 2008 | 08:50 PM
Nitro Dave's Nitrous Outlet's Avatar
I do not have the jetting with me now since I am at home. However we have the jetting at work and the jets you may need instock. Give us a call and we can give you the info you are looking for.
Dave
Old Jan 9, 2008 | 11:49 PM
ls1camaro's Avatar
thanks everone
Old Jan 10, 2008 | 12:08 AM
J_Z28_T's Avatar
Default same ? kinda
so u can use a low pressure stand alone on a efi car i asked that earlier, u just have to get the right jetting im asuming by the responses on the threads? please help
Old Jan 10, 2008 | 12:18 AM
b00sted's Avatar
Yes. There's quite a few people doing it that way.
