wiring and activation of second stage nx
Old Jul 2, 2003 | 11:43 AM
mobius's Avatar
Default wiring and activation of second stage nx
how do you guys wire the second stage up? do you make it run off of the activation of stage one and then add a push button or something to activate the second stage?
Old Jul 2, 2003 | 06:20 PM
B18B1LS1's Avatar
Default Re: wiring and activation of second stage nx
You could use another button all together, I have my second stage wet kit hooked through my horn button. Or you can buy something like the Ramcharger timing tuner to activate it, but with that your only looking at .8 seconds max. I believe you could also buy one of NOS's nitrous controllers with a delay on it, then run the first stage with a WOT like usual and then tune the controller to your setup. Some of the NOS units are fully adjustable up to 10 seconds of delay I believe.
Jeffrey
Old Jul 2, 2003 | 08:15 PM
BMN's Avatar
BMN
I got a quy with a blown 95 GT running one of my window switches to not activate his spray untill second gear. You could leave your 1st stage hooked up to the WOT and the the 2nd stage to my window switch and let it kick in when you hit second automaticly. Let me know if your interested.
Old Jul 3, 2003 | 04:17 PM
mobius's Avatar
i have a window switch for the first stage. i think i may run the second thru the first stage relay and then have a pushbutton to activate the second.
Old Jul 3, 2003 | 08:02 PM
mobius's Avatar
i got it diagram on nx page about 2 stages
