New user with questions
Old Jan 7, 2008 | 07:07 PM
fastlsx's Avatar
Default New user with questions
I have a stock bottom end LS-1 with ported heads, 12.5/1 compression, and a Comp Cams 232/236, Lift 595/601 camshaft.
I am planning on installing a dry nitrous kit. I would like for it to be hidden, and would like to know how much I can spray to the motor?
Any help with this would be buch appreciated.
Let me know if you need more information.
I also have a aftermarket fuel pump, so fuel shouldn't be a problem.
Thanks
Tom
Old Jan 7, 2008 | 07:33 PM
madclown's Avatar
I think you will run into problems with the injectors. I have done alot of research and it looks like a wet plate kit will be a little safer. Good luck and have fun.....
Old Jan 7, 2008 | 07:36 PM
waterbug1999's Avatar
Injectors for sure... Your prolly pushin the limit with those all ready on motor.
12.5.1 CR? You running race gas?
