N2O Set-up question
Old Jan 7, 2008 | 09:14 PM
OldskoolRcr's Avatar
Default N2O Set-up question
I am running a GM style intake with the elbow, and a Fast 90mm T/B. This is the question I have, since it is the GM style intake it is a 4150 flange, what would be the best set up for N2O wet. Using a 4150 style plate under the elbow, or using the basic "in front of the MAF" stlye with the nozzels. I am running the NX Gemini kit on my other LS1, with a LS6 intake, which works awsome. Please any input would be great. Thank you
Old Jan 7, 2008 | 10:29 PM
b00sted's Avatar
I'd definitely run the 4150 plate under the elbow.
Old Jan 8, 2008 | 12:10 AM
99mongooSS's Avatar
yeah use the new ZEX plate its great dist. I used one on my 79 Z28 on top my carbed 383. with a 150 shot made 600rwhp.
Old Jan 8, 2008 | 01:46 AM
b00sted's Avatar
<<< NX Hitman. Works awesome.
Old Jan 8, 2008 | 04:59 AM
wolfy's Avatar
<- speedtech 4150 plate system here. best carb plate you can buy, hands down!!!
Old Jan 10, 2008 | 10:40 PM
4150 it is...But I have a simple question. The 4150 plate kits require 5-10psi fuel press. depending on witch kit you buy...who makes a F/P regulator that reduces the high press. of the EFI pumps, to the low press. required for the 4150 plate kits. Thanx.
