wire question
Old Jan 13, 2008 | 10:30 PM
Ruckus46Gt's Avatar
Default wire question
I just wired up my bottle heater ran the power wire up to the battery and i plan on running my relay and all the wires for the kit under the glove box. Instead of running another wire back out to the battery can i tap the wire i ran to the heater relay for my nitrous kit relay. I would tap it before the bottle heater fuse and run a fuse for the nitrous kit relay also. I believe the wire is a 10g, basically i'm asking would it be to much current through the wire from the battery to the firewall where it would split
Old Jan 14, 2008 | 09:50 AM
Chris@NitroDaves
Guest
Posts: n/a
Because the bottle heater pulls so much amperage I would suggest that you run a second hot wire for the nitrous kit. Also since the system isn't going to pull as much amps as the heater you could get away with using 12g wire for that.
-Chris
Old Jan 14, 2008 | 02:40 PM
Ruckus46Gt's Avatar
thanks the responce wasnt sure how much it pulled. tech probely wouldnt have both engaged at once but just in case i'll run a seperate one
