Big MAF spray
. How much can u spray through 85mm MAF one nozzle drilled .125? Looking for 250rwhp. Logged 13396hz at 483.12g/s on a .062 jet. I am on E85 and was not lean according to WB, which read .79 lambda or 7.74 AF. Trying to figure out max. Looking for more.
OK, 483 g/s is pretty high of a load, and if your a/f is as rich as you claim, your dumping way to much fuel. Your not quite maxing the MAF (512g/s) but close. E85 is whole new ball game. Is it set-up n/a for e85. Your MAF is getting better than a good reading, to good for the e-85. I would get an HSW Interface and dial in the a/f, this will bring your g/s down also, and MAF freq. Hope this helps some. if not clear let me know and I will try again.
Robert
