Wiring relay question
Old Jan 23, 2008 | 12:19 AM
dementia's Avatar
Default Wiring relay question
I've got a 0 or 1 gauge wire running directly from the battery to my trunk space. It was previously wired for my sub but since my amplifier blew I've taken out the sub since its just dead weight. My question is in wiring up my nitrous since my bottle is trunk mounted could i wire the 12 volt sources for the relays off of that wire or is that not recommended? (relays for the bottle/heater and pressure sensor). I just dont feel like running another set of wires the entire length of the car if I can avoid it.
Old Jan 23, 2008 | 09:42 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Yes you can run the 12v constant sources to that wire.
You should be able to pick up a nice distribution block to make going from the large gauge down to the smaller feeds to each relay easy and would make for a very clean install.
