lean shutdown switch and timing tuner questions....
Old Jan 26, 2008 | 02:17 PM
Clean94Z's Avatar
Default lean shutdown switch and timing tuner questions....
Can someone tell me (if its possible) how you can use both the dynotune lean shutdown switch and the harris speed works nitrous and timing controller since they both want to use the ground on the nitrous system...how do I wire the two up?
