TPS Switch & Window Switch Question?
Old Jan 26, 2008 | 02:52 PM
MiamiGTO's Avatar
Default TPS Switch & Window Switch Question?
If I have a window switch their is really no point in having a TPS switch correct?? If my Nitrous rpm is activated by a window switch I should not need a TPS to worry about my throttle body position correct? I am just worried about my throttle blade not reacting as fast as I hit the gas..
Old Jan 26, 2008 | 08:04 PM
99FRC's Avatar
Can you get to 3000 RPMs without having it at full throttle? Then yes, you need a TPS.
99 FRC
Old Jan 26, 2008 | 10:59 PM
madclown's Avatar
Or use a WOT switch...........
