fpss
Old Jan 27, 2008 | 07:00 PM
00silverGTP's Avatar
Default fpss
is this needed? I have heard it causes some problems. will I be ok without it?
Old Jan 27, 2008 | 07:11 PM
jmill96Z's Avatar
For whatever problems you may have with it, it will more than make up for them if you fuel pump takes a dump while you're spraying.
Old Jan 27, 2008 | 07:12 PM
Fbodynewbie's Avatar
I may be retarded but are you talking about the fuel pressure safeteyy switch if so I work with heilcopter systems pushing up to 3100 psi + and we use them religously. You lose fuel pressure and your Nitrous is still spraying your looking at some nasty stuff happening
Old Jan 27, 2008 | 07:16 PM
99FRC's Avatar
Old Jan 27, 2008 | 07:41 PM
point taken...
Old Jan 27, 2008 | 11:06 PM
BayAreaSS's Avatar
ITs so cheap that it would be stupid not to buy it
Old Jan 28, 2008 | 11:29 AM
WS6FTW's Avatar
Run it Eric. It's affordable protection.
Old Jan 28, 2008 | 11:25 PM
Nitro Dave's Nitrous Outlet's Avatar
The fuel pressure safety seitch is a cheap piece of insurance. Most problems people have is because they do not understand how to adjust it. This is why buying from Nitrous Outlet is a pluss. If for some reason you can not understand from reading the instructions or just simpky want to talk to a knowledgable tech one of our guys can walk you right through it.
Dave
