FREE Nitrous System & Accessories!!!
where is the bottle heater?
where is the purge kit?
where is the pressure gauge?
whoever wins the kit is going to have to spend money with yall either way you look at it....we are doing alot of advertising for yall just to be giving away the basics
thanks anyways though
Brand X Nitrous Systems are designed for the fuel injected enthusiast looking to add reliable horse power gains up to 200 hp. All Brand X Systems come with the following Components.
1. Black 10lb bottle with high flow 90 degree valve.
2. Stainless Steel quick release style bottle brackets.
3. Small body solenoids rated up to 200 hp.
4. 1/16 wet nozzle or 1/16 dry nozzle
5. 1/16 nozzle adapter
6. Jetting up to 150 Hp.
7. 16ft Main feed hose.
8. 2ft supply hoses to nozzle
9. Relay with Harness
10. WOT. Switch and bracket.
11. Bottle nut.
12. Bottle nipple.
13. Universal solenoid brackets.
14. Solenoid fittings.
15. Wire.
16. Hard ware pack.
17. Electrical pack.
Good Luck.......
Thank you for your support!
Dave
