Looking to add a sneaker shot.. help please
Old Jan 30, 2008 | 04:57 PM
ScreaminBird99's Avatar
Default Looking to add a sneaker shot.. help please
Im looking to add a little sneaker shot to my fbody, i have full bolt ons and a 224r cam, anyone got a link to a complete kit, that has the jets for 50-75 shot, id really appreciate it. also as far as tuning/timing what has to be done when installing a nitrous kit? I heard retard timing.. change spark plugs... with this small of a shot do i need to go with fuel system upgrade?
Old Jan 30, 2008 | 05:33 PM
Mike@HSW's Avatar
You wont need to pull timing for that sized shot, nor will you need to upgrade your fuel system. Were you thinking about running a dry or wet shot?
here is a link to our sudden impact series. i think a single nozzle wet system will do you just fine.
http://www.harrisspeedworks.com/shop...cat=364&page=1
Old Jan 30, 2008 | 05:56 PM
Nitro Dave's Nitrous Outlet's Avatar
We have quite a few applications that could fit your needs. Since you have a cam I assume your timming has been changed. Depending on how aggressive the tunning is you may need to remove some timming. If that is the case the ways I would suggest that are reliable to remove timming are computer tunning or a timming tunner or MSD timming Twister.
If I can help in any way Please hit me up.I can show you several of options and see what best fits your needs.
Dave
Old Jan 30, 2008 | 06:12 PM
Mike@HSW's Avatar
I appologize, did not notice you said you were running a cam (sorry been a long day). Depending if your tuner advanced timing to get more NA power, you may one to pull two degrees or so. As long as your back to stock timing you shouldnt have a problem.
I am assuming with the cam upgrade you also upgraded your spark plugs, do you know what you are running now? TR-55 or TR-6 should be fine.
