timing for 100 shot
Old Jan 31, 2008 | 04:07 PM
texasheat's Avatar
Default timing for 100 shot
Just checked the tune on my car and its running 29-31 degrees at wot. With mods in sig. how much timing would u pull to run a 100 shot safely???
Old Jan 31, 2008 | 04:15 PM
LS699TA's Avatar
with an ls1 id say keep it 27-28 at the MAX , ideally id have it at 26
Old Jan 31, 2008 | 04:28 PM
jmill96Z's Avatar
You might want to pull a little timing. There's no way I would spray my car with 31 degrees. 28 is about the max that I'm comfortable with.
Old Jan 31, 2008 | 05:00 PM
texasheat's Avatar
I have a timing tuner...I just wanted to see how much timing need to pull. So you guys are thinking I should pull 5 degrees?
Old Jan 31, 2008 | 05:28 PM
jmill96Z's Avatar
26-28 for 100 shot
24 for 125-150
20-22 for 175-200
That's what I use, and don't have any problems with a Torco 104 blend.
Old Jan 31, 2008 | 05:41 PM
texasheat's Avatar
Ill be running 93 octane pump gas.
