Shortblock ? for 300 shot
Old Feb 3, 2008 | 10:10 AM
Orangepeeler's Avatar
Default Shortblock ? for 300 shot
The motor will be an LS1 out of an 01 Corvette. I was wondering what you would recommend for the short block. Do I need a forged crank or can I just do rods and pistons? Could I even get away with just rod bolts and a good piston? I wiil be running it with a progressive controller set at 100 on launch and building from there. Any help would be appreciated.
Old Feb 3, 2008 | 07:51 PM
n2ocamaro's Avatar
I noticed a 3rd gen in your avatar. Without assuming its a TPI, what type motor are you running? As far as your question on rods, pistons or just pistons, the rods take the most abuse in the rotating assembly. With a shot that size, I recommend you spend as much as you can in the bottom end. It will give you peace of mind later.
Old Feb 3, 2008 | 07:59 PM
Sorry, I wasn't very clear about my combination. I am putting together an 01 LS1 out of a Corvette in the car. My understanding is that the cranks are pretty stout. There seem to be different opinions on the rod bolts but, I would more than gladly replace them if need be. I know that the pistons will need to be replaced at this level so that I WILL do. Thanks for the reply. The original post has been updated.
Old Feb 3, 2008 | 08:09 PM
n2ocamaro's Avatar
The cranks in the LS1's are pretty stout. You could do rods and pistons only as long as the stock crank checks out OK. I hear the bigger problem with LS1's is the heads lifting on large shots. Since I am not an expert on LS1's, hopefully someone who has a large shot LS1 will chime in.
