What Size Purge Line?
I will be getting a hood with firehawk heat extractors, and I figured I would purge out of both of those.
So my purge selenoid is mounted on the TB, and will have a T-Fitting and line running to the extractors
Since this is a fairly long distance, I don't want to waste a ton of juice, but I still want it visable.
I was planning on using Aluminum tubing?
Sponsors? what do you suggest since you guys have tons of gas to pass
Yeah pretty much going for the looks and something different. Should look pretty sweet
