Running line from trunk??
Old Feb 6, 2008 | 12:41 PM
Bill Bowling's Avatar
Default Running line from trunk??
I have my tank in the trunk. How does everyone run the line?
Bill
Old Feb 6, 2008 | 12:50 PM
DopeFedZ's Avatar
https://ls1tech.com/forums/nitrous-oxide/857648-how-where-run-mainline.html
Old Feb 6, 2008 | 03:36 PM
I saw that thread but that was from the spare tire location and do not want to run the line on the inside of the car.
Thanks.
Bill
Old Feb 6, 2008 | 04:21 PM
quickblade's Avatar
I believe there is a drain plug there also..
What you will want to do is make that drain hole perfect for your line, drop line down under car and up against the fuel line...
you can follow the fuel line up to the engine compartment.
Should be good running it there.. you can strap it or zip tie it....
I prefer straps with zip ties for the extra hold down...
Old Feb 6, 2008 | 06:59 PM
5_02ls1's Avatar
i ran mine under the back seat andthrough the body plug...
