Introducing The New Maximizer From NX
Old Jul 11, 2003 | 02:10 PM
Nitro Dave's Nitrous Outlet's Avatar
Default Introducing The New Maximizer From NX
We are proud to offer NX's new controller.The Maximizer.
This is the only controller on the maarket with with a built in RPM activated window switch with a gear counting feature,and the first to have a built in TPS voltage sensing switch to activate the system.The Maximizer also has a delay and ramp feature.This unit will ramp up or down for turbo cars,and you can also change the ramp parameters for each gear.The unit will hooks up to your 02s to read the air/fuel ratio and allows you to cut the nitrous off at any given ratio.
This unit is retailing at 650.00.
Order now and be one of the first to get it.
1-866-648-7637
Thanks
Dave
Old Jul 11, 2003 | 04:32 PM
Ed Blown Vert's Avatar
Default Re: Introducing The New Maximizer From NX
Can't get to your Site. Wants a password
Old Jul 11, 2003 | 06:18 PM
Ed,
We are trying to find out what is going on.Bare with us.
Thanks
Dave
Old Jul 11, 2003 | 10:43 PM
DONAIMIAN's Avatar
How big is it. Pic would be nice, but a general size will do.
Old Jul 12, 2003 | 01:58 AM
CAT3's Avatar
Restricted User
Size wise it is about 4"x41/2". A post from SilverZ, rep for NX, answered that "?" after I asked him. Theres a link to pic in that post, showing the NXL and the controller. Controller can be programmed I believe w/ a PDA as well as a laptop.
Old Jul 12, 2003 | 11:11 AM
BLUE01Z-28's Avatar
is that just for the nxl kit ?
Old Jul 13, 2003 | 07:48 AM
CAT3's Avatar
Restricted User
Blue01Z-28, thats the size of the controllers main bpdy, theres also a small relay much like the normal N2O kits.
Old Jul 13, 2003 | 01:06 PM
Blue01Z-28.
No this unit will work with all other kits also.
Old Jul 13, 2003 | 05:42 PM
Country Boy's Avatar
Senior Member
Is this a time based unit or RPM based?
Old Jul 16, 2003 | 01:29 AM
Holden's Avatar
I'd like to know too. Sounds like it might be time based???
Old Jul 16, 2003 | 02:05 AM
CAT3's Avatar
Restricted User
You can program from time, rpm, or a new gear selection.
Gear selection is kinda like this, you put in that you have 4gears and your jetted for a measley 200shot. You set first gear to spray from 0-33% (or hp terms of a 200shot max, from 0hp-67hp)then 2nd gear from 25%-60%(50hp-120hp), 3rd from 50%-80%(100hp-160hp) and 4th from 75%-100%(150hp to that little 200hp!).
Do a search in here for a post from SilverZ, I think page two of it has the info.
Old Jul 16, 2003 | 03:09 AM
Holden's Avatar
Thanks, but I have read SilverZ's thread a few times, and to me it doesn't state clearly if the ramp feature is based on rpm, time or both. I hope you are right
The gear feature looks good.
Old Jul 16, 2003 | 03:54 AM
383LQ4SS's Avatar
Ya know...after thinking about the gear feature....it must have some rpm based control. Otherwise...how would it know where the ending ramp % would take place for each specific gear. The other thing about the gear feature...I dont think it will work unless you begin from 1st. There are no other means I can think of to keep track of gears except starting in 1st and counting up each time the computer sees a dip in rpm.
Old Jul 16, 2003 | 10:12 AM
CAT3's Avatar
Restricted User
Al, you got a good set of points, as usual. But, have you ever tried to launch an A4 in 2nd at the track.....mmmmm no good.
Old Jul 16, 2003 | 10:49 AM
383LQ4SS's Avatar
Lol...I was more thinking from the M6 perspective as usual. Meaning..you cant be driving down the strret in 4th and then downshift to 2nd and get the programmed amount. I think you have to start from a stop in first gear.
I wish they would release some detailed info on the darn thing.
Old Jul 22, 2003 | 12:29 PM
iateyourcat's Avatar
Dave, I don't see it on the site yet.
Old Jul 22, 2003 | 12:36 PM
Heh, and your voicemail is full.
Old Jul 22, 2003 | 02:42 PM
WS6snake-eater's Avatar
Yeah NX's description on their site sux.
