close or open bottle
Old Feb 13, 2008 | 10:50 AM
black01_WS6's Avatar
Default close or open bottle
does someone want to open or close the bottle when there is no juice in the bottle. By opening it does it save the bottle valve longer, or can dust and particles get in when open?
Old Feb 13, 2008 | 11:54 AM
rss0694's Avatar
Just put the kit on fill the bottle and you wont have to worry about it.
Old Feb 13, 2008 | 01:02 PM
quickblade's Avatar
If there is no juice, then I would not see why it would matter too much open or closed.
Unless you are taking bottle in and out of car all the time, it should be hooked up to all your hoses...
So even if you left it open, the most dirt that could get in there would have to travel thru the solenoid, then up the line, thru the filter if you have one, then into the bottle.
I am thinking with no juice, which ever way makes you happy will be the way to have it.
IMO.. keep it closed.
Old Feb 13, 2008 | 04:51 PM
Well do you have any extra money laying around. I still need some **** to make it work correctly.
Old Feb 13, 2008 | 05:18 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
leave the valve closed when not in use.
