how much et drop to expect from nitrous
everything is already there except for the traction bars.
if i get too close to 10's ill have to upgrade from the truck intake to a fast and upgrade the single 3" exhaust to dual 3"...its only $$$ right hahaha. i plan on upgrading my rod bolts from stock to kaetech, but does anyone think the stock motor will hold together? its way past the 100,000 mark. only motor mods are a cam and patriot heads.
Its a lot of work but if you want to upgrade the rod bolts that would certianly help your chances of keeping it together. ide also look into upgrading your oil pump and timing chain. I would still go with a progressed 200 shot as well
plug change is 10 minutes to me haha. maybe ill duel stage it and push as much as i can out of the hole, then put the rest as soon as i can hook it. ill probably relocate the battery to the back for some extra weight on top of the tires and to get some off of the front of the truck. every little bit counts this far huh? still daily driven
My goal is 9.5's in the 1/4mi or better. i got a FJO progressive controller, NX wet kit good to a 250 shot, nx bottle heater, nx bottle heater controller, nx bottle jacket, nx bottle opener, nitrous outlet plate, fpss and nitrous outlet switch panel.
its scheduled to go to ARD next thursday morning and they will have it ready friday evening. since i made this post ive added the traction bars, and changed cams. i also switched from the truck intake manifold to the LS6. it dynod 429hp and 390tq. my truck should be good for an 11.9x on motor now.
starting with a 150 and working my way up to a 200.
