window switch woes
Can you see the display from the drivers seat?
What is the read out when you arm it, and when you first deck it?
Even at 4.4 volts that is a realy on the ragged edge of wot voltage, ANY rearward movement of your leg or amp load will change the number.
Try setting it to 4.0-4.2 volts.
Now when you deck it what rpm are you at? 1600? it will take a moment to hit your target rpm activation window.
if you want give me a call to walk through the tech, sometime easier to talk then type.
940-781-5204
chris would it read lower with the car driving and hitting wot or higher? Cause it activates the nitrous when it see's over the displayed tps volt value correct?
Oh yea when i moved it down to 4.4 and 2900 it hit a little sooner, basicaly right at the end of the 60' (able to pull off a 1.79 instead of a normal 1.82)
When you arm the system your read out should show,
0 0 0.
at wot 1 0 0
at wot and low rpm 1 1 0
no wot at low rpm 0 1 0
1 is on
O its off
L is locked out.
You should not need to drive the car if you are getting a good tps reading.
I think your rpms are nto climbing as fast as you may think. Watch the read out will let you know what is going on and when it is happening. If there is anyother delay it could have to do with line length, or maybe other electrical.
