window switch and A4
Old Feb 18, 2008 | 07:12 PM
dubrado's Avatar
Default window switch and A4
I'm set to spray 3000-6200 but w/the new stall I never really see under 4000rpm after shifts.
I don't want to spray through the shifts.
So with it set like it is right now, will it spray through the shifts? I'd rather have it shut off before redline and then kick back in after the trans has had time to switch gears.
Old Feb 18, 2008 | 08:26 PM
mchdg86's Avatar
Set it to shut off just before the computer commands the shift and you should be fine.
