Question for any NANO gurus
And filling the NANO bottle wont help anyways...thjat is until th4e nitrous was empty...then you would get whatever misxture you put in thr NANO bottle to go into the nitrous bottle and eventually wind up in the motor.
So your experiment would be better with a nitrous bottle hooked up as usual...but instead of nitrous use compressed air and whatever other additive (02 or whatever)
Actually compressed ait and an exact amount of 02 may work...or 02 and nitrogen. But you would have to exactly control the ratios or your tune will be off.
Thats one of the reasons for N20. Its composition is fixed. Second thing about N20 is it doesnt break down and make those 02 molecules available until compression.
Try it!
Try it!
As a master diver, and a certified gas blender, I only go for the exact mixture of nitrogen and oxygen I asked for in my Nitrox tanks. Yes, the oxygen in nitrox can be checked and controlled, and the main thing I would be concerned with is the fact that it would deteriorate o-rings and seals quicker. It's a lot harsher on components. However, if you mixed the oxygen percentage just a little lower than the same amount in nitrous oxide, then you'd get just a slightly lower hit, so you'd know you were out of nitrous oxide, but wouldn't completely kill your et. Or, once you run your bottle out, you can still play at the track, filling your nano bottle from a scuba tank if you had an adapter. Over 40% O2 is where you really have to start seriously treating oxygen with care. Under 40%, you can basically treat it normally. If doing the blending myself and not with a membrane system, 100% I don't go above 1500psi...so that would be 33% at 4500psi. Let your tank sit over night, then you're good to go and it's thoroughly mixed and consistent. Check it with your analyzer and fill your nano.
I know that there have been various things stated as to why scuba tanks wouldn't work for added power, but I think that with this type of setup, it might actually work to get you through a day. You'd definitely have to check your bottle valves more often and replace any o-rings more often, and rebuild your nitrous solenoid more often.
I know I'm thinking about this a lot more than it's worth, but call it curiosity.
