for those who run a window switch
also, who all actually runs a FPS switch? there comes a point when a motor is to lean it just doesnt run? therfore is a fuelpump dies is this really going to blow the motor?
yes i did a search but im not finding what im specifically looking for. i have a BMN window switch that im debating on installing. no longer with a manual so i dont know if its worth the install.
Another thing is the drive line, if the tranny, driveshaft, or rearend fail the engine will over rev. With nitrous the problem is much much worse, so absolutley get a window switch for just peace of mind.
FPSS are a pump fail safe not a absolute. Meaning they are designed and set to catch if your fuel pressure is falling. Set it to close to your operating pressure and you will get an on/off/on/off bouncing problem you will notice.LOL fuel pump dies while on nitrous yes more time then not the engine will have some damage.
do not know anything about the BMM stuff.
