Pushing water....
Robert
I am trying to do all this on pump gas, it's my goal. I want to be able to bust into the upper 130's on spray and run a bottom 10. All on pump gas and 17" radials. I REALLY want to do it without race gas. This is a 95% street car. I can barely afford the nitrous as a poor-broke-college-kid, let alone race gas.
The build sheet on the motor claims 11.5:1. With the pistons, gaskets, deck height, and heads it should be 11.3-5:1 or so, so if anything, it's less, unless they used a different gasket than specified. Patrick told me my DCR would be about 8.3:1 with the cam I've got now.
383LQ4SS - I was under the impression that you could put 80 ft-lbs on the iron block with ARP studs? I didn't install the heads, but they clicked the torque wrench at 50 ft-lbs when I was checking, so I moved it to 70 and it clicked again w/out moving.
1lejohn - Do you know the part number for the gaskets? I'm assuming they're for a 4" bore? Mine's a 4.03.
If you really want pump gas...you really need to go over your static and dynamic compression stats, veryfy EVERYTHING yourself....a cam change may be in order. Maybe Patrick will help you there. You will have to use the coldest plug so its not a concern..a 7 should be ok...maybe an 8 for good measure.
Then youll have to log your runs and put the best tune you can on it. Stay on the rich side on juice. low 11,s AF ratio and pull as much timing as you need so there is NO detonation.
It is possible a cam change will be in order.
Another thing to do is adjust the rpm range you are spraying. The higher the activation point the less likley detonation is to occur. And who knows when your head gaskets where comprimised...it may have been messing around on the street when spraying right at 3000 rpm...and from there its all downhill once the gasket is comprimised. If you are spraying from 3000-7000 or something like that...try raising the activation point up a bit. Maybe even 4000 rpm on. That will reduce the cylinder pressure seen in a big way but not really slow you down at the track.
Its all in the details man. I think you should be able to run your numbers on GOOD 93 octane myself. But you will have a small margin for errors such as bad gas or mistakes on the tune.
The first weekend I had it going and hit the 100 shot 2-3 times I was ready to pill it up.
I may just have to look into a standalone. I can get race gas about 10 minutes from my house if absolutely needed.
What about Octanium? $16 bucks extra per full tank doesn't sound bad. It may be just enough if I do still have problems. I've been doing quite a bit of research on it and it seems to have helped quite a few people get their detonation problems lined out. I haven't read much about it on here though.
I have the same problem. On N/A its all fine and dandy but mid summer this past year, I noticed after I spray the 100 shot, I am loosing water and its not coming out of the radiator cap.
I believe I am at 24* of timing on the jug (26* total and used the 2* per 100 shot rule).
I am also at ~11.5.1 CR and running TR6 plugs.
So, I guess after reading this thread and after I fix the head gasket leak, I should retard my timing some more and put say a #7 plug in?
I plan on hitting the 200 shot and trying to squeak into the 9"s this year, thats my goal.
also at 11.5 cr and had tr6 plugs. ive since swiched to 8's. Did you change the timing any? I have had ~20 bottles thru the motor on teh 100 shot and no signs of any issue other then losing water on the juice.
I try really hard to run 100 octane while spraying anywhere rather it be the track or the street. But, there was a few times over the summer where I was forced to get 91 octane and I did spray on it. So, I am guessing thats where I got my gasket leak and now it leaks no matter what octane I put in.
Robert
I had no idea that the standalone tank would last so long as you guys are saying lol. 11.5:1 air/fuel by weight means I'd burn up a lot of spray before that fuel ran low, never thought about it before.
PS - I couldn't find much info on gapping TR-7 plugs either. .032" or so sound about right?
