Do i need fuel pump and injectors?
I plan on running a 200 wet shot progressive. I was going to just get a stand alone and run 116 when i spray through the stand alone set up. But im not sure if i need to upgrade the stock fuel pump and injectors as well or not???
If i do end up having to upgrade the injectors and fuel pump can i just skip the stand alone and run the 200 shot on 93 octane or is that not a good idea?
You could do a pump and not have to run the standalone but you lose the added octane in the standalone system.
