My bottle heater quit working...
Im not sure where to start so i checked to see if there was voltage to the relay and there was. Other than that im not sure what needs to be checked. HELP
If you have 12v on 85 & 86, but nothing on 30, check the line that comes to 30. Did you fuse the line? Is it ok?
If pin 30 checks out but nothing on 87 (check voltage between 87 to ground with switch on) the relay is bad.
If all those check out, but still no heater, your heater could be toast.
please?
