bottle heater problems
Old Mar 3, 2008 | 04:02 PM
ls1transam346's Avatar
Default bottle heater problems
installed a harris speed works bottle heater. followed the wiring diagram supplied when i hook the battery back up i hear the relay kick on and the light on the switch is lit up even though i have it on the off position and the heater element starts heating up. any ideas of where i went wrong? open to suggestions.
Old Mar 3, 2008 | 04:44 PM
well i figured out the problem.
Old Mar 3, 2008 | 05:29 PM
Mike@HSW's Avatar
You are always welcome to give our tech line a call if you have any problems. You'll usually get a faster response if you do run across anymore issues. As usual we are always glad to help out. Glad to see you got the wiring worked out.
Old Mar 3, 2008 | 06:07 PM
actually it was one of your tech guys that helped me. the reps were busy earlier so i posted the thread. then i got through and the problem was solved. i appreciate everything and i will definitely give ya'll a call if i have anymore problems.
