Nitrous Help!!!
Old Mar 6, 2008 | 06:01 PM
RealArmyMan's Avatar
Default Nitrous Help!!!
Is the MSD Digital Window Switch programmable? Meaning, can I, myself, program what gears to spray in, and within a specific RPM range? Or does it come pre-programmed. This is an a4 LS1 btw. Thanks.
Old Mar 7, 2008 | 01:04 PM
021less's Avatar
it has pills with it for desired range, you may have to buy different pills for it though, not sure which ones it comes with. But your answer is yes, you can program it yourself by just changing the pills.
Old Mar 7, 2008 | 01:39 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
The MSD digital switch is user programable...but you can only set the ON/OFF RPM's. It does not have a gear lock out feature.
http://www.nitrousoutlet.com/catalog...product_id=818
Our digital switches will give you the option of gear selection, RPM window, and TPS activation.
Single stage
http://www.nitrousoutlet.com/catalog...roduct_id=2885
Dual Stage
http://www.nitrousoutlet.com/catalog...product_id=964
Old Mar 7, 2008 | 11:14 PM
Single stage
Dual Stage
Thanks Ray. I just ordered that. Thankfully the MSD was backordered and someone named Chris emailed me to let me know. So it was as easy as cancelling that part and ordering the new one that you recommended. I also dropped your name on the site. Just in case that does anything for you.
