Some Grounding Questions and Mounting Qs
Old Mar 14, 2008 | 12:40 PM
00cls1camaross's Avatar
Default Some Grounding Questions and Mounting Qs
Is this a good ground
Like the loom?
Is it ok to zip tie this to the radiator hose? Will it get to hot
Any problems with the spot for mounting the relay?
Old Mar 14, 2008 | 08:23 PM
TTT, i just need a few answers before i continue. This would be my first time doing it.
Old Mar 14, 2008 | 08:45 PM
Robert56's Avatar
Our cars are real finicky when it comes to grounding. If you can, a ground directly at battery, or one of the junctions close to battery is best. Bad ground spots can cause all sorts of issues, and I couldn't tell where you grounded yours at. Relays are good really anywhere, just keep em away from excessive heat. tying off to the raiator hose is probaly not the best option, and I wouldn't do it.
Robert
