couple wiring questions
Old Mar 16, 2008 | 07:17 PM
00silverGTP's Avatar
Default couple wiring questions
ok I am starting to wire my kit up.
1. should I use a separate relay for the purge?
2. where is the best place to mount the relays? I mounted mine by the battery.
3. can I use all one ground?
Old Mar 16, 2008 | 07:46 PM
BOTTLEFEDLS1Z's Avatar
1. NO
2. I mounted my heater relay in the back and the kit relay is inside the glove box
3. Depends, but you can ground the relay and the solenoids off the same ground. Do not ground anything to the ECU ground connection
Old Mar 16, 2008 | 09:03 PM
so I only use one relay for the kit and purge and one for the heater?
Speed Density's Avatar
hashtagBMW
Curious, but why not?
Old Mar 17, 2008 | 08:44 PM
For example, if you had a progressive controller like a FJO, you don't want to ground to the ECU. A pulsing solenoid can generate electrical noise that can interfere with the ECU
That's right!!
