wanting to put TNT on the Z..help
Old Jul 23, 2003 | 10:50 PM
I8AFORD's Avatar
Default wanting to put TNT on the Z..help
OK
Im going to put the bottle on the Z
what all do I need as far as safety stuff,,window switch etc.etc..
thanks
Jason
does anyone have pics of their TNT kit I could see?
Old Jul 25, 2003 | 07:06 PM
Navy David SS's Avatar
Default Re: wanting to put TNT on the Z..help
Many of your questions can be answered by using the search.
But: IMO - best kit TNT wet F1, you'll need just a window switch (a must on the M6). To go more that 100 shot (to be safe) you should upgrade fuel pump and injectors (if you haven't already). Make sure you monitor you runs via A-tap.
You can take a look at my site. I have some really poor shots of my set up.
Good luck
David
Old Jul 25, 2003 | 09:04 PM
ggr12's Avatar
I just recently installed my TNT F1 kit last weekend. Did all the hardware install install one day and the wiring the next. Pretty straight forward except for the custom bracket making we did. Ive only tested the 75 jest and so far its good. Ive got a MSD window switch with 3800 on and 5700 off for now, stock stall and shift points until i can get a tuning device. Also have a FPSS. Everythign works great, i can try and get some pics up by monday on my site.
NavyDavid, was jw why you would need bigger injectors for a wet kit since the kit itself provides the fuel. i know the fuel pump would be needed but hwy injectors also?
