Maintaining bottle pressure?
Old Mar 24, 2008 | 10:15 PM
dnkynrbk's Avatar
Default Maintaining bottle pressure?
Does hooking up 2 bottles and connecting them with a y help at all in maintaining pressure. Saw a post before from ROBERT on this. I know the nano does but wandered if anyone is doing anything else. Also what nitrous pressure gauge are you running electric one is what I need info on.
Old Mar 25, 2008 | 06:44 AM
dnkynrbk's Avatar
anyone
Old Mar 25, 2008 | 07:10 AM
Beer99C5's Avatar
The Dynotune Nitrous Gauge is a great piece, if your going to log nitrous pressure though the voltage it uses is to narow to accurately log with EFI Live, so i had to switch up to a Autometer sending unit.
Old Mar 25, 2008 | 12:31 PM
landonew's Avatar
Yes it does, but with the nano it is not cost effective. Reasoning is that for the price of an extra bottle, and 2 heaters (one for each bottle) you could almost buy a nano kit. The nano will work better as well, in that it uses nitrogen to push the N2O instead of just heating the N2O causing it to expand to create the optimum bottle pressure. Robert I believe runs 2 bottles, but he has been around a while and I beleive his setup was completed before nano came around.
Old Mar 25, 2008 | 06:09 PM
GueSS Who's Avatar
You can run the system at what ever pressure you want. We run our cars at 900psi..We have adjusted the fuel to compensate for 900psi. It is hard to make the bottle pressure drop when it starts at 900 to begin with. I don't have any pressure drop but I run 2 bottles. 137mph in the 1/8
Old Mar 25, 2008 | 06:46 PM
dnkynrbk's Avatar
so how do you run the 2 bottles both blankets wired together then run a both hoses to a y then to your main line. I have two bottles and 2 heaters allready. I want to do the nana but do not have the 550.00 at the moment. Is it worh it or not. thanks
Old Mar 26, 2008 | 10:18 PM
myfast70's Avatar
Well if you have everything already, you may as well stick with your setup. If you decide to go NANO and use two bottles, you are going to need two NANO kits
