Help with picking nitrous stuff please...
Old Mar 25, 2008 | 02:49 AM
Ryan33187's Avatar
Default Help with picking nitrous stuff please...
I want to be able to go on the street and everything I was thinkin about doing a full turbo setup and such, but the more I look at nitrous kits the more I seem to be in awe over them.
Well I am looking at this kit right here:
NX-20220: NXL LS1 w/10lb Bottle: http://www.nitrousoutlet.com/catalog...roduct_id=1395
MSD Digital Window Switch :http://www.nitrousoutlet.com/catalog...product_id=818
NX-11107: Remote Bottle Opener :http://www.nitrousoutlet.com/catalog...&product_id=70
I want to get the dual ntimidator red led purge kit... can't seem to a find one that is not blue leds though .
Looking at these guages:
Auto Meter 6478 - Auto Meter Digital Air/Fuel Ratio Wideband Gauges :http://www.jegs.com/i/Auto%20Meter/105/6478/10002/-1
Auto Meter 5974 - Auto Meter ES Series Gauges Nitrous Pressure :http://www.jegs.com/i/Auto+Meter/105/5974/10002/-1
Auto Meter 5963 - Auto Meter ES Series Gauges Fuel Pressure :http://www.jegs.com/i/Auto+Meter/105/5963/10002/-1
Pillar:
Auto Meter 12213 - Auto Meter 2-1/16'' Triple Gauge Full Pillar Pods :http://www.jegs.com/i/Auto%20Meter/105/12213/10002/-1
I think that is everything what do you guys think?
I have bolt-ons right now... ported / modded oil pump by thunder racing, subframes, and tranny cooler sitting in my room atm... Would this be a reliable setup for my street / light track use? Almost 60k miles...
Old Mar 25, 2008 | 06:05 AM
MeanWS6's Avatar
are you planning on future internal mods to the motor?
im running just a simple twin nozzel NX 250shot; upgraded fuel and dont forget plugs. GO with a 15LB bottle and buy from dave or speed
Old Mar 25, 2008 | 06:58 AM
Beer99C5's Avatar
Consider the Trick Performance Gauge, it uses the autometer sending units, its two gauges in one (you can do Nitrous and Fuel Pressure or Nitrous and AFR), as well has the heater control built in as well as lean shutdown if your using the AFR or Fuel pressure cut off if using the fuel pressure gauge...
Old Mar 25, 2008 | 07:15 AM
Mike@HSW's Avatar
how much are you planning on spraying?
Old Mar 25, 2008 | 12:49 PM
Ryan33187's Avatar
150 or 200 shot Ya I kinda like that trick performance gauge I was thinin about gettin that.
