Sprayed 6-Speeds Come In!
http://www.nitrousoutlet.com/catalog...product_id=964
That's the one I'm buying! *I want that free nitrous kit* I was talking to Edgar (LS1Cantu) from Xessive Motorsports and he said he was going to order that one for me. My car is one of the first LS1's he worked on. *I want that free nitrous kit!* I practically live at his shop and he's recomending you for my parts! *I want that free nitrous kit*
Robert
if you don't power shift you will be fine. i have mine cut off at 6800 and shift at 6600. if you can speed shift i see no point in power shifting.
This is great! These are the exact kinds of pointers I need to hear!
even if i miss a shift i am ok since my rev limiter is set at 7k. if you let off the throttle when you shift, you will not spray throught the shift. i see no point in coming off the spray after your window and then again when you shift. you are just losing et. as long as you have your window switch cut off before your rev limiter you are ok.
Robert
Robert
So you spray 360 hit wheel or engine? I see you have 6xxhp numbers in your sig on a 408 with a 360 hit? What does your car run on that 360 hit?
