Nos mini wiring programing a 2 stage
Old Apr 6, 2008 | 10:41 AM
dnkynrbk's Avatar
Default Nos mini wiring programing a 2 stage
Ok maybe I found my problem on the set up of this. Guys running a 2 stage set up please tell me how you set your mini on the programing. I have the tps wired and to activate at wot and have the first stage comming on at 3200rpm and the 2nd stage comming on 2.5 sec. later. Both stages shut off at 6400 rpm. step c I have it 04 for the rpm reading so I have been told to match my rpms. the tps mode I have it set #8 on the program at 01 I have the tps setw/e pedal all the way to the floor. Im spraying 100 shot 1st stage and 100 shot the 2nd. The window display says both stages are comming on. I have tested them with the car off and the rpm set at 0 and having someone hold the line in a bucket. And they both sprayed. I took it to the track and it ran and it sucked. I made 3 full runs. I only used 3 lbs of nitrous and in my standalone I only used a 1/8 of fuel in the tank. So maybe the 1st stage comes on and when the 2nd stage comes on maybe the first shuts off. thanks for any imput
Old Apr 6, 2008 | 07:53 PM
dnkynrbk's Avatar
anyone
Old Apr 6, 2008 | 08:22 PM
jow02327's Avatar
dam man wish i could help. can you not feel the second stage coming on?
Old Apr 6, 2008 | 11:33 PM
dnkynrbk's Avatar
yea I cant feel crap on the 2nd stage says its on. I think I do not have the settings right. Maybe the ramp pause mode. I have broke loose and had to let off it then re hammert he pedal so I dont know if its resetting its self. Any imput or how anyone has there 2 stage programed please let me know what your setting are.
