Dynotune Lean Shutdown Display...
Old Apr 7, 2008 | 06:22 PM
MetallicaMatt's Avatar
Default Dynotune Lean Shutdown Display...
where the HECK are you guys mounting them? I'm trying to find a nice, clean, trick spot, but haven't had any good ideas
Old Apr 7, 2008 | 07:34 PM
1969mach1's Avatar
The DynoTune A/F Ratio Lean Shut-Down Switch?
Glove box, I think would be a good spot.
Some people should post up pics of where they have mounted their electrical parts.
Old Apr 7, 2008 | 07:44 PM
caliswangin916's Avatar
i have mine mounted where the red rectangle is. the yellow is a half circle hole that i cut into the guage cluster bezel using a drill bit. just big enough for the wires to go through. the blue represents the wires. the a/f lean shutoff switch is mounted using velcro. it only slightly obscures the gas guage. probably more so than that pic would depict.
Old Apr 7, 2008 | 08:41 PM
cool
anybody else?
I'd like to keep it out in the open to monitor everything since I'm using the wideband
