Will a 98 Computer keep up with a dry shot?
Old Apr 8, 2008 | 04:51 PM
patriotformula's Avatar
Default Will a 98 Computer keep up with a dry shot?
Thinking about spraying a 50 dry shot or 75 dry shot through my SLP Maf... Will a 98 computer be able to keep up enough to supply the extra fuel? I have a 46lb injector so I have more then enough injector... Thanks in advance! I'm fairly new to the whole spraying thing on ls1s... Also what jet would you guys call a 50 shot?
Old Apr 8, 2008 | 04:59 PM
bad6as's Avatar
short answer is yes.
Old Apr 8, 2008 | 05:28 PM
Dabeztz28's Avatar
With 46# injectors you be able to spray more than a 75 shot. Just make sure your fuelpump is up for it
Old Apr 8, 2008 | 05:39 PM
Beer99C5's Avatar
No problem, just keep in mind nozzle position plays an important role as well.
Old Apr 8, 2008 | 05:41 PM
ls1408cp's Avatar
so spraying a 200 dry on a 98 computer would work?
Old Apr 8, 2008 | 06:35 PM
Any advice on nossle position? How close do you fellas think I am to pushing the stock fuel pump too far already with the 46# injectors?
Old Apr 8, 2008 | 07:09 PM
ls1408cp's Avatar
I will run the nx plate thing it looks slick
Old Apr 8, 2008 | 07:30 PM
ls1408cp's Avatar
doesnt a 98 maf max out sooner?
Old Apr 8, 2008 | 10:16 PM
TheBlurLS1's Avatar
That's what she said...
Yep. 11250hz instead of 12500 (or 12000?) with the 99+. Mine, with the stock MAF, is VERY close to being maxed out N/A (408 stroker). The MAF doesn't max out, per say, but the computer's operating system can't deal with MAF values over 11250. Once the computer sees 11250hz, it sticks with the last airflow value in the table even if you're flowing more in.
Old Apr 9, 2008 | 12:14 AM
ls1408cp's Avatar
HSW Interface Air to Fuel & Timing Controller
is this any good? will it work on a 98 car? I just got done reading 11pages about it and learned nothing.
Old Apr 9, 2008 | 12:28 AM
383LQ4SS's Avatar
How much are you looking to run?
Changing injectors goes a long way to running large dry shots....even on a 98
Hell I have run about 475 total rwhp on a bone stock 98 with no tuning with a dry shot.
Old Apr 9, 2008 | 12:39 AM
ls1408cp's Avatar
It wil be a heads cam lq4 with a 175 shot max. I will have 60 pound injectors and a 255 inline with a 8an feed line. i hope the 255 inline will be enough
Old Apr 9, 2008 | 01:06 AM
383LQ4SS's Avatar
I think you should get by easily with that setup. I would do an intank over the inline though.
Old Apr 9, 2008 | 08:35 AM
ls1408cp's Avatar
I dont have a stock tank anymore, I have a fuel cell
Old Apr 9, 2008 | 08:41 AM
PAGregSS's Avatar
A stock '98 fuel system will support a 150 shot. The computer is not an issue.
I will be using the HSW Interface this summer. I'm looking forward to it. I'm replacing my Timing Tuner with the Interface.
Wait, you said LQ4. Is that a 370? 408?
I agree, you would be further ahead with an intank pump.
If I were running a dry shot setup again, I'd use one of Nitrous Outlet's Halo setups. When I was running dry, years ago, I had the nozzles mounted in the air lid.
Old Apr 9, 2008 | 09:02 AM
ImStock's Avatar
LQ4 is the 6.0 that comes in the trucks.
ls1408cp's Avatar
I think The nx plate dry setup on the maf looks easier. I might just run an a1000. It is the only pump that isnt expensive and moves a decent amount of fuel.
Old Apr 9, 2008 | 11:38 AM
PAGregSS's Avatar
I had an LQ4 block that I was building into a 408, I'm aware of their origin. Just unusual to see people actually use the stock LQ4 shortblock, when it's easy to get a 370 with an LS1 crank.
