cam/nitrous
Old Apr 14, 2008 | 09:42 PM
HoTrOd HaRrY's Avatar
Default cam/nitrous
Looking to purchase a cam that goes good with nitrous. Daily driver. Any ideas?
Old Apr 15, 2008 | 12:15 AM
landonew's Avatar
You want a general NA cam. IT will respond decently to N2O, and still make good power during DD conditions. A true nitrous cam is typically best for track only cars, that will run primarily on nitrous. That being said, this is the wrong forum. Also, it would help to know whether you are running a ls1, ls2, or ls7. Cams will vary depending on displacement.
Old Apr 15, 2008 | 01:48 AM
RAGENZ28's Avatar
Maybe some thing like 224/230 with 600 lift and a lobe between 112-114, the wider lobes work great with nitrous and will also idle smoother than a can with a 110 lobe a lot of the N/A cams are ground on.
