How much nitros if any?
Old Apr 15, 2008 | 07:12 PM
guns77's Avatar
Default How much nitros if any?
Let me start by say I know vary little about nitrous but am interested in learning. I currently have a 01 formula m6 with stock bottom end . I will be adding a h/c/i package this month.Heads will most likely be tsp 5.3 heads and there 228cam with a typhoon intake. Anyways the question is will I be able to add a small shot of nitrous to that set up (50-100) or will the compression be to high or will there be other complications, if I can add it should I go wet or dry? Thanks alot
Old Apr 15, 2008 | 11:56 PM
Nitro Dave's Nitrous Outlet's Avatar
You can safely spray up to a 150 on the stock bottom end. You will get tons of biased suggestions as far as wet or dry. I suggest studing both and seeing what best fits your needs and capabilities. Keep in mind you are going to need to upgrade the fuel system to feed all those newly found ponys...
Let me know if you have any questions.
Dave
Old Apr 16, 2008 | 02:15 AM
Gimp98TNT's Avatar
I did 250 wet shot with TSP 5.3L heads and a old futral cam 225/233 i believe, ran good.
