Questions about nitrous fill station/pump.
Question 1 - Do I need to heat up my mother bottle? I have a small household heater that I could use. I know I need to get a pressure gauge too.
Question 2 - Does the temperature matter on the bottles I'm filling? Should I chill them? They'll most likely be warm from the hot Texas weather.
Question 3 - Will the pressure be too high if I'm filling a half full bottle that's kinda warm already or one that already has a lot of pressure? I'm worried that when I add to the bottle, I'll exceed the max pressure and I'm not sure if many of the racers down here install burst discs.
Question 4 - Should I offer to freeze-fill for customers who don't mind waiting(if I have the space in my deep freezer). It only takes a couple hours right?
I'd appreciate any help or advice ya'll could give me.
I am setting up to do the same thing, just waiting on my bottle stand for non siphon Mother bottles from Chris @ Nitrous Outlet.
Gonna do what the other shops do, look for the MT weight on the bottle and add 10 (for a 10 pound bottle) to the fill weight on the scale (or ensure bottle is empty weigh it, and add 10 for fill weight).
Spraying will be enjoyable now that I don't have to drive two hours round trip for refills!
I figured that's how it should be done, but I wasn't sure. I was reading all these topics about people getting air instead of nitrous, or exploding bottles. Then some guys were saying they wouldn't even go to a shop that used a pump rather than a freeze-fill.
Racers around here travel about that far to get their refills too. Hopefully I'll be the new "source" for refills down here.
I keep the mother bottle in the garage put the smaller bottle in the freezer for 20-60 mins just depends on temps and fullness of both botles.
Be careful it is easy to overfill a bottle using this meathod I will put 11-12lbs in my bottle but only 10 in others. Most shops around here will only get 8-10 lbs with a pump.
I came home with a full 7lbs once
I tell my friends to freeze/chill there bottles b4 they come if they can.
Keep track of what you use you get ~45-50 good easy fill lbs from a 55-60lb bottle, I use the last 10 for my self as it takes longer to fill.
BTW way why would you do it in your Living Room?
NO
Yes and Yes
It can be but since I dont use a pump mine never are.
Yes and no
I would tell them the colder they bring the bottle the better and faster the fill.
#2 is consistancey, start filling bottles too much and it's gonna **** with your tuneup.
If you're just goofing on the street and not actually racing for real, I guess it doesn't matter though
