860 heater wiring Q
Old Apr 17, 2008 | 12:53 AM
Johnnystock's Avatar
Default 860 heater wiring Q
I bought a used 860 bottler heater(130$) and theres no pressure switch/hardware and I dont have the instructions or wiring schematic with it.
3 things:
- Can someone post a wiring schematic of the 860 heater?
- didnt everything 860 kit came with an automatic heater or its because mine might be too old?
- and is it ok to run the heater without the automatic feature?...what would be the correct way to wire this??
thanks in advance guys cause I'm installing my kit since the last 3 days and I'm at the end of it!!!! any advice is welcome!!
Old Apr 17, 2008 | 09:55 AM
Nitro Dave's Nitrous Outlet's Avatar
The 860 heater is offered in several versions. Automatic and heated bracket only.
Regardless of which one you bought it should have had isntructions in it. You can find instructions here.
http://www.860performance.com/manuals.asp
Old Apr 17, 2008 | 12:57 PM
thanks a lot...do you recommend buying the pressure switch?
Old Apr 17, 2008 | 01:34 PM
SY732's Avatar
Its up to you if you want it how many bottles do you have?
If you only have one and it has a spare port go for it, it does add some extra wiring and it takes a few seconds to hook it up each time you put the bottle in.
But once its all done set and in, you dont have to watch it as much.
Old Apr 17, 2008 | 11:15 PM
ok cool...I think I'll keep it that way cause I cant wait to finish the whole thing...
