N2O install basic questions
Old Aug 1, 2003 | 02:47 PM
onebadz's Avatar
Default N2O install basic questions
hey guys i was thinkin about gettin a N2O kit and was wonderin about how much is a regular install and how difficult it is. and is a 100 shot aight with my mods or do i need anything else
Thanks for tha info
Wes NC
Old Aug 1, 2003 | 03:00 PM
ChazLS12002's Avatar
Default Re: N2O install basic questions
A hundred shot should be just fine,not sure how much install is, but I KNOW its not bad the worst part is running all the lines just time consuming. Also, I would get some tires!!!
Old Aug 1, 2003 | 03:33 PM
CAT3's Avatar
Restricted User
You should be able to do install if you can handle minor hand tools and basic wiring. Might take 3hours by yourself, as long as you search thru here for install pics and such to help your routing. The hardest part is not knowing how exactly to bend the little activation arm in the WOT switch. I would not use the HPP3 tuning though, seen to many people mess the shift points up and resulting bent valves etc...
Good-luck.
