HSW Interface Controller
Old Apr 21, 2008 | 10:52 PM
00WickedRedTA's Avatar
Question HSW Interface Controller
Quick question about the interface controller from HSW... If I already have a dual nozzle dry before the MAF, how does the controller interact with what the MAF sees already? Will it add more fuel according to the shot size I specify on the controller...? How exactly does that work?
Old Apr 22, 2008 | 11:03 AM
Jpr5690's Avatar
Yup If You Spray Before The Maf Then You Will Not Need The Full Sized Shot Correction Factor
My Advise Is To Just Set It Up As If You Sprayed Post Maf And Then Back Down The Interface's Fuel Corrsction Until Your Wideband Is Happy
In My Case I Really Didnt Need Any Adjustment After My Maf Read The Spray
Also Make Sure You Scan The Car A Few Times And Check That The Interface Is Working.. I Had Issues With It Not Being Able To Pull Timeing As It Was Advertised
Old Apr 22, 2008 | 12:17 PM
Awesome. Thanks.
