Window switch
Old Apr 21, 2008 | 11:14 PM
Josh Nickelsen's Avatar
Default Window switch
Can anyone tell me if there are any big difference's in the Nitours Outlet, Dynotune and Zex window switches. I have an msd right now and I am having a diffucult time getting it to work with my zex wet kit and lean shutdown switch. I think using a different window switch will make it go a lot easier. If anyone can tell me if there is really any difference between the 3 and if they will all work fine with the zex kit, it would be great!
Thanks!
Old Apr 22, 2008 | 12:19 AM
Beer99C5's Avatar
The Dynotune and Nitrous Outlet window switch are made by Trick Performance and are Two stage window switches, they are the same.
The Zex I believe is a single stage.
Old Apr 22, 2008 | 12:28 AM
So they will work fine with my setup and all I have to really watch out for is to set the second stage to like 7000. Is that correct? I have been reading about them and I seen someone post that you need to set the second stage high enough that it won't work. Is this correct?
Thanks for the reply!!
Old Apr 22, 2008 | 07:56 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
NO, if second stage is not connected to anything the programming for it will matter not.
If you have a ZEX kit, use the Zex window switch. They are different.
