2 stage with hsw interface and a wet kit ?
Old Apr 24, 2008 | 09:00 AM
uscg02ws6's Avatar
Default 2 stage with hsw interface and a wet kit ?
I guess the best person o answerer this question is going to be Robert56 but any ways. I have a nx wet shot and I want to kno if I can use the HSW interface to use convert the wet kit in to a 2 stage dry after there MAF ? I’m assuming I could just split the n20 line to go to each of the noids and then add anther relay. Would this work and what r your feelings about this kind of set up ?
Old Apr 24, 2008 | 09:52 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
You cannot use the fuel solenoid to flow nitrous. The internals are not designed to handle nitrous pressure levels (~1000psi), most fuel solenoids are only rated for (~100psi)
To run a 2 stage dry kit will require 2 nitrous solenoids.
Old Apr 24, 2008 | 09:58 AM
uscg02ws6's Avatar
ok thanks for 4 the info
