Need to Settle This
Old May 8, 2008 | 12:33 AM
BirdofPreyBandit's Avatar
Originally Posted by xXxSilveradoxXx
Oxygen is not being forced into the engine with a Nitrous setup. A naturally aspirated engine sucks in air which we all know is Nitrogen, Oxygen, Argon, Carbon Dioxide, Water Vapor and trace amounts of other chemicals. When Nitrous is applied it oxidizes the air and cools it at the same time so the engine sucks in oxygen enriched, cooled air. So, as you can see, air is not being forced, it's just being changed.
I know that the engine produces a certain amount of suction but my argument was that it should be considered forced induction because the bottle's pressure pushes the gas into the intake and down the heads and into the cylinders. If it relied solely on suction, then a nitrous bottle's pressure wouldn't need to be more than maybe 5 psi...just enough to get the liquid/gas through the line and out the nozzles. But, again...that's just me.
Old May 8, 2008 | 02:26 AM
xXxSilveradoxXx's Avatar
I doubt the bottle has the ability of pressurizing the intake track to anything above ambient. If you raise the pressure higher than ambient the Nitrous will flow in the direction of least Resistance. It would be less resistant to flow through the air filter out to atmosphere instead of raising the pressure of the intake track.
The bottle is pressurized higher than 5 PSI to increase the amount of Nitrous Oxide in the bottle. For instance, at ambient (14.7 PSI) one cubic foot of Nitrous equals one cubic foot of Nitrous. Now, if you have one cubic foot of Nitrous that is pressurized to 1000 PSI above ambient you would have 69.02 cubic feet of Nitrous at 14.7 PSI. (I believe that is the right formula, it's been a while)
