What is the biggest shot i can run on a dry kit???
Old Aug 5, 2003 | 11:09 AM
Danny's Avatar
Default What is the biggest shot i can run on a dry kit???
What's the biggest shot i can run on my car. I've heard of 150shot but then again i'm hearing bigger shots. Fuel system upgrades include a Walbro pump and stock 28lb injectors. The reason i want to go with dry is because i want to hide my kit.
I had an NX kit before and that really gave me a kick in the butt. But i want to hide this kit. It's impossible to hide the wet kit.
Any comment will be grealy appreciated.
Engine is a stock LS1 w/ an M6 and 3:73 w/ 8.8 rearend.
Thanks
Old Aug 5, 2003 | 11:56 AM
SSpray's Avatar
Default Re: What is the biggest shot i can run on a dry kit???
I would not spray more than 150. But with your upgraded fuel system you might be able to...it still wouldn't though.
Old Aug 5, 2003 | 12:07 PM
bmbutler's Avatar
I'm running the NOS-5176 kit (150 shot dry) and it has been fine so far with my stock motor.
Of course, this kit includes the NOS imline fuel pump (85-90psi).
it also has a tuning suggestions chart on the instructions which suggests Fuel Quality of at least 92 octane, ignition timing can be stock, and plugs can be stock to 1 step cooler. The jetting used on this kit is .067" (150 hp at flywheel)
